Changes between Version 4 and Version 5 of notes
Ignore:
Timestamp:
09/18/08 12:28:55 (14 years ago)
Author:
daley
Comment:
formatting changes
Legend:
Unmodified
Added
Removed
Modified
  • notes
    v4 v5
    1818
    1919The important sections are:
    20 2. Quick Start
    21 3.6 The runtime parameter file (flash.par)
    22 5. The FLASH configuration script (setup)
     202. Quick Start,
     213.6 The runtime parameter file (flash.par),
     225. The FLASH configuration script (setup),
    232322. Timer and Profiler Units
    2424
    6464timers and not the in-built FLASH timers.  Timing data for any
    6565labelled code section therefore appears alongside routine level data
    66 in the TAU profile, e.g.
    67
    68 [[email protected] MULTI__GET_TIME_OF_DAY]$ pprof -p -n 20 -s
    69 Reading Profile files in profile.*
    70
    71 FUNCTION SUMMARY (total):
    72 ---------------------------------------------------------------------------------------
    73 %Time    Exclusive    Inclusive       #Call      #Subrs  Inclusive Name
    74               msec   total msec                          usec/call
    75 ---------------------------------------------------------------------------------------
    76 100.0         27.3      7829590          32          96  244674686 FLASH
    77  59.6         48.2      4663871          32         224  145745970 DRIVER_EVOLVEFLASH
    78  57.7         1145      4516119          32        6410  141128734 *** custom:evolution
    79  40.4         2155      3165100          32       14603   98909381 DRIVER_INITFLASH
    80  40.0          148      3130132          32         768   97816632 *** custom:initialization
    81  39.2          218      3071459         640         640    4799155 *** custom:hydro
    82  39.2          325      3071241         640        1280    4798813 HYDRO
    83  39.2          657      3070915        1280        2560    2399152 HY_PPM_SWEEP
    84  31.9         29.2      2493992          32         128   77937243 GRID_INITDOMAIN
    85  31.8          329      2493440          32        1741   77920004 GR_EXPANDDOMAIN
    86
    87 "*** custom:" prefix indicates a FLASH labelled section.
     66in the TAU profile.  FLASH labelled sections are currently marked using the
     67"*** custom:" prefix in the TAU profile.
    8868
    8969This can be included in a FLASH simulation by passing the following
