Changes between Version 3 and Version 4 of ParNCLDeveloperInfo/RunningNCLScript
Ignore:
Timestamp:
12/11/12 12:16:07 (7 years ago)
Author:
jacob
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • ParNCLDeveloperInfo/RunningNCLScript
    v3 v4
    77ParNCL is a parallel program that uses the Message Passing Interface.  You can run it, in parallel, on any modern laptop or workstation that has a multi-core CPU (all modern one's do) using the "mpiexec" command.   You can also run it on a cluster or other supercomputer if you have access.
    88
    9 The binaries are currently built with the MPICH2 version 1.5.  This version is available [http://www.mpich.org/ here].    See section 2.2 of the [http://www.mpich.org/documentation/guides/ MPICH Installation Guide] for the quickstart.
     9The binaries are currently built with the MPICH2 version 1.5 and you'll have to build and install its "mpiexec" command before you can use ParNCL.  This version is available [http://www.mpich.org/ here].    See section 2.2 of the [http://www.mpich.org/documentation/guides/ MPICH Installation Guide] for the quickstart guide to installing.
    1010
    1111Be sure you can run an example program in examples/basic before you try to run ParNCL.
